i have a question for you about the idle speed of my car. It actually has to do with when u start it. When started, it runs hits 2,000 rpms and keeps rising until it is at an upwards of 3,200 or more and then in about 5 min. or less it will slowly decrease and then go to a very low idle so it sounds as if it will quit. A good friend and car fanatic told me that i should check out the vacuum with a meter to check if there is a leak because that can cause the problem. i was wondering what you input on this subject was if he was correct and what u believe the problem could be.
P.S. do i need to use a credit car to donate money?
Aug 10, 2008 at 6:56 PM
