Codes p000A, p0302, and p0301, misfires?
2011 HONDA PILOT
180,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
CLANSIDEL
Hello, I have the vehicle listed above that has engine code p000A and misfires p0301 and p0302. The engine surges and is low on power. The timing belts look okay. Does this indicate a camshaft sensor issue?
Sep 12, 2023 at 8:07 PM
Yes, I would start with the camshaft position oil control valve and if it is okay change out the sensors and then clear the codes because the sensor can cause additional codes.
P000A - "A" Camshaft Position Slow Response Bank 1: This code typically points to an issue with the camshaft position sensor or the camshaft itself.
P0301 - Cylinder 1 Misfire Detected and P0302 - Cylinder 2 Misfire Detected:
Also, check the ground as shown in the images as well, also make sure the engine oil is clean and full.
See if the oil control valve has gunk or metal shavings. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Sep 13, 2023 at 11:58 AM
CLANSIDEL
Thanks for the information. I figured out the problem, it was an insect wedged inside the mass air flow sensor. I cleaned it and it runs 100%. Crazy! Thanks again!
Sep 13, 2023 at 12:09 PM
CLANSIDEL
Also, just to mention the info you provided was for a 2.4 Honda element not a Honda pilot 3.5 but still good information.
Sep 13, 2023 at 12:19 PM
Gotcha, good find on the problem, use 2CarPros anytime, we are here to help. Please tell a friend.
Sep 14, 2023 at 10:30 AM
