97 honda passport 130,000 miles.. trouble starting
1997 HONDA PASSPORT
ASHLEY_NOY
My honda passport will not start unless you pump the gas or hold it down while starting , once it is started it reves by itself for a few secounds then turns to normal, now just recently the "check engine" light turned on. What can i do to make it start normally?
Oct 27, 2007 at 9:54 PM
BMRFIXIT
  • 19,053 POSTS
[quote="ashley_noy"]My honda passport will not start unless you pump the gas or hold it down while starting , once it is started it reves by itself for a few secounds then turns to normal, now just recently the "check engine" light turned on. What can i do to make it start normally?[/quote
It could be bunch of thinks (vacuum leak-- over due for a tune up --idle air--TPS--low coolant--…) but I will start with the check engine light first
Have the truck scanned for code s that will direct you to the trouble area
Good luck
Oct 27, 2007 at 10:05 PM
