1999 Honda Passport Tail lights
1999 HONDA PASSPORT
14,300 MILES • 6 CYL • 2WD • AUTOMATIC
SETTLE00
15 a fuse required but blows everythime you turn lights on. 20a works but gets hot. Checked all wiring and cant find a crimp or exposed wire. Also replaced relay and searched behind steering column. Small accident on front right headlight that tore wiring for headlight. Respliced wires and all is fine except taillights. FRUSTRATED!!!
Aug 20, 2008 at 5:56 PM
KHLOW2008
  • 41,814 POSTS
Hi settle00,
Try unplugging the bulbs for combination and taillights and turning on the light switch.
If fuse is ok, start by plugging in one by one, check the bulb sockets for shorting first.
Aug 30, 2008 at 9:42 AM
