1997 Honda Passport Overheating
1997 HONDA PASSPORT
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROBERT WEBB
My vehicle is leaking coolant from the somewhere in the middle of the engine from the bottom. When I drive it after about 3 or 4 miles it overheats. It was overheating before but it wasn't leaking on the ground so the repairman said to change the thermostat and we did. After that it started leaking like crazy. Is this the water pump or could it be some internal hose or Whats causing it to overheat and leak coolant?
May 25, 2010 at 10:21 AM
KHLOW2008
  • 41,814 POSTS
Hi Robert Webb,
There are bypass hoses and water passages at center of engine and any of them could be leaking. You would need a viausl inspection to locate the source.
May 25, 2010 at 12:54 PM
ROBERT WEBB
Thank you for your reply!
May 25, 2010 at 12:58 PM
KHLOW2008
  • 41,814 POSTS
You're welcome.
Have a nice day
May 25, 2010 at 3:05 PM
