My vehicle is leaking coolant from the somewhere in the middle of the engine from the bottom. When I drive it after about 3 or 4 miles it overheats. It was overheating before but it wasn't leaking on the ground so the repairman said to change the thermostat and we did. After that it started leaking like crazy. Is this the water pump or could it be some internal hose or Whats causing it to overheat and leak coolant?
May 25, 2010 at 10:21 AM
