1996 Honda Passport white smoke
1996 HONDA PASSPORT
165,000 MILES • 4 CYL • 2WD • MANUAL
CJOHNSON779
The head gasket was changed Due to a overheating problem when put back together we had white smoke out of the exhaust. just wondering if we have a cracked head or something else is wrong?
Thanks for any help you my have!!
Aug 4, 2008 at 7:00 PM
MMPRINCE4000
  • 8,548 POSTS
The head is either cracked or warped, the mechaniics should have checked the head for any indications of warpage. It is also possible a headbolt is stripped.
In any case you want to get this repaired ASAP, if coolant gets into the oil you are looking at damage to the main bearings and coolant will kill an O2 sensor very quickly.
Take it back to the garage that originally did the work and simply tell them it is was not repaired properly.
You may need a new head, or you may find a good used one at a junkyard.
Aug 5, 2008 at 5:27 AM
