Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Honda
Passport
Engine
Cylinder Head
Valves
Adjust
1996 Honda Passport valves
1996 HONDA PASSPORT
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
NUCKLEJAMMER
MEMBER
FOLLOW
Can the intake and exhaust valves for the 3.2L
V/6 be adjusted and if so, "how"
Thank you: Ron:
Mar 4, 2009 at 11:28 AM
RACEFAN966
CERTIFIED EXPERT
This engine has hydrolic lifters and no valve adjustment can be made. Thanks.
Mar 4, 2009 at 3:23 PM
NUCKLEJAMMER
MEMBER
Are you telling me that I can't even shim to take out excessive gap between cam lobe and valve bucket.
Thank you - Ron:
Mar 5, 2009 at 10:44 AM
THIS IS MIKE
CERTIFIED EXPERT
That is correct, they are not made to be adjusted.
You may have excessive sediment in the oil and that may be causing the valve train noise. Frequent oil changes seem to help.
Mar 5, 2009 at 2:56 PM
