1995 Honda Passport
1995 HONDA PASSPORT
CARLOT95
Electrical problem
1995 Honda Passport 6 cyl Four Wheel Drive Automatic
I have lost fire to about 4 fuses under the hood fuse pannel they are fuel pump blower motor and the 2 headlights what could have happen
Updated 11/25/09
there is power to those to fuses I ran a jumper wire to the fuel pump and the car runs and I looked under the fuse box and no loose wires this is the main fuse box under the hood
Nov 22, 2009 at 1:46 PM
KHLOW2008
  • 41,814 POSTS
Hi carlot95,
Do you mean power is not getting to the fuses? If yes, you most probably has a faulty fuse box. Check the Main fuse # 1 ( 60 A ) and Main fuse # 2 ( 30 A ).
Nov 24, 2009 at 9:21 AM
KHLOW2008
  • 41,814 POSTS
Always reply to this post so that notification would be sent to the person attending to you.
If you run a wire from the battery to the fuses, does it work?
It could be an internal fault with the fuse box.
Did you check the fuses mentioned above?
Nov 25, 2009 at 2:23 PM
