You didn't provide me the make, model, year and mileage of your car so I can't make an accurate judgement.
If the engine spins over like you have no spark pulgs in the holes then it is a broken timimg belt You can remove the valve cover and see if the valves move when you turn over the engine.
As a reminder, the timing belt replacement on most Hondas is 60K on earlier models and 90K on newer models.
Good Luck
May 27, 2006 at 1:18 PM
