Starting problem
HONDA
ADAM339
I have a 1997 Acura integra. I tried to start it and when i turned the key nothing happened. I checked the battery for charge, and it had plenty of juice. I cleaned all of the corrosion off of the battery terminals and checked all the wiring from the battery, and it seemed fine. Then i tried starting it again and got a buzzing noise from somewhere in the dashboard, and the engine still won't even try to turn. What could the problem be? I'm completely stumped.
Mar 22, 2006 at 2:23 PM
VANDRAGON
  • 298 POSTS
ir you got a buzz after cleaning, you might want to replace the connectors on the cables. if you have a charger, charge the battery or take it out and have a parts store to charge it. by the way, how old is the battery? my van had a 7 year battery in it that died at 4 and a half. altenator could be weak also.
Mar 22, 2006 at 4:17 PM
BRUCE HUNT
  • 3,754 POSTS
I would say the terminal connections are still not making good contact and replace them.
Mar 25, 2006 at 11:34 PM
