loosing coolant
HONDA
DIRTVIPER
my friend is having problems loosing coolant.we did a pressure check and we are loosing pressure. we also have done a compression check which is good accross the board. around operating temp it starts pushing coolant to the overflow tank. what would cause the car to be loosing coolant after replacing the radiator, radiator cap, water pump and thermostat.
Feb 20, 2007 at 3:06 AM
[quote:4402931498="Dirtviper"]my friend is having problems loosing coolant.we did a pressure check and we are loosing pressure. we also have done a compression check which is good accross the board. around operating temp it starts pushing coolant to the overflow tank. what would cause the car to be loosing coolant after replacing the radiator, radiator cap, water pump and thermostat.[/quote:4402931498]
Sounds like a blown headgasket
Feb 20, 2007 at 2:39 PM
