Fuel pump
HONDA
I'm not getting any power to my 1993 Cicic 265000 mile car. So I put a new fuel pump on the car but I'm still getting no power. Can you help me.
Aug 31, 2006 at 9:41 PM
SYNCRAIT
  • 235 POSTS
elaborate a little for us from the time you turn the key tell us everything that happens including noises, smells, the more info the better to help you with more accurate answers.....good luck lemme know :)
Sep 1, 2006 at 7:36 AM
well when I try to start the car it tries to start but nothing. I'm not hearing the pump excite at all. I tested the main relay as the mech book suggests but it's ok. I tried to the jumper wire test to see if there is a code issue but the check engine light stays on. Someone suggested the ecu but I can't find it . may be you have a suggestion you'd like to share.
Sep 5, 2006 at 1:36 PM
