Front passanger side wheel
HONDA
JOHNDJ88FAN
i have a 98 isuzu rodeo and the front pass. side wheel sounds terrible kinda of grinding noise, almost like im dragging something. I can push the 4wd button and this noise stops. I used to be able to push the 4wd button and move forward and then push it again to disengage and then back up and this would cure this noise for a while. Seems like the noise would come back when i hit a big bump. But now it will not stop making this noise unless the 4wd button is engaged. Thanks
Nov 14, 2006 at 1:21 PM
BRUCE HUNT
  • 3,754 POSTS
Sounds like the beginning of a bearing problem or an automatic lockout that is failing. Post to the right forum for better help from their moderator. However, I would check those items out.
Nov 15, 2006 at 8:35 AM
