cars seems to "give" under applied load.
HONDA
TOFKREW
not sure if this is clutch issue or someother. THe car seemed to "flutter"and kinda buck when i shifted from 1 to 2 in low rpm. THen immeadiatly the engine light came on. After that I stopped at a light, then every gear i shifted at around 3K the car seemed the flutter" and buck since that It's like the the engine wants to die but then regains it self at a higher rpm. THe car is a modified 1.8 ls-vtec, 1993 acura integra with a stage 1 racing clutch. This just happened. im afraind to drive it. i just kept it under 3k the whole way home.
Feb 9, 2006 at 4:35 PM
GEARSHIFTER
  • 20 POSTS
Have you made it into higher gears.
Feb 10, 2006 at 12:15 PM
TOFKREW
yeah i can go in every gear fine.. but cant take it past 3.5k..i also didn't notice at first. but it does it in neutral too. i think it might have to do with something with the valves....i dunno
Feb 10, 2006 at 10:47 PM
