Car Won't Go Pass 65mph!!!!!!! :(
1965 HONDA
BIGCHRISTIAN2K2
I have a 91 Acura Integra with 200,000 miles on it. I let my sister drive it out of town and when she came back the car engine light came on. Now whenever i start the car up when the car is cold i can punch it. As soon as the engine light comes on i can't accelerate real fast the car jerks if i do and vibrates real hard. I get on the freeway and my car won't go pass 65 mph. If I stop the idle will go real low like its going to cut off. Sometimes it does.
Mar 18, 2006 at 8:09 PM
VANDRAGON
  • 298 POSTS
with that many miles, it sounds like the cat-converter is clogging up and will only get worse. good luck!
also if you smell that something is getting hot, the parkbrake could be stuck.
Mar 19, 2006 at 10:28 AM
BRUCE HUNT
  • 3,754 POSTS
Find the codes of the check engine light. It really sounds as though the computer in shutting down and causing the car to run in a default mode that does not read the sensors and adjust to outside conditoins, etc. Find the code.
Mar 20, 2006 at 2:03 PM
WGRACE07
  • 11 POSTS
[quote:f4bbc3b44d="bigchristian2k2"]I have a 91 Acura Integra with 200,000 miles on it. I let my sister drive it out of town and when she came back the car engine light came on. Now whenever i start the car up when the car is cold i can punch it. As soon as the engine light comes on i can't accelerate real fast the car jerks if i do and vibrates real hard. I get on the freeway and my car won't go pass 65 mph. If I stop the idle will go real low like its going to cut off. Sometimes it does.[/quote:f4bbc3b44d]
The jerking to the side sounds like one of your axles is broken--my car was doing that when I'd do an occasional peel out for fun and I just thought it was part of the process. Maybe she hit a really bad pothole or something; you could always pretend you know what she did and see if you can get her to admit to it.
Jun 7, 2009 at 2:03 AM
