brake very low
HONDA
CIVICUSER
  • 13 POSTS
I just replaced my front brake pad about 3 weeks ago. when my brake pads were replaced, they seemed fine and sharp and you don't not apply the brake pedal very deep to stop the car.
But after about 3 weeks, I would have to apply my brake pedal very deep to stop my car and the brakes doesn't seem as sharp as when they were just replaced.
I check the brake fluid, it is still near full. What seem to be the problem? and how to fix it?
Nov 8, 2006 at 2:46 AM
BRUCE HUNT
  • 3,754 POSTS
Sometimes when you put on the brake pads the fluid is backed up in to the resevoir as a result of compressing the caliper. This pushes the fluid back in to the master cylinder or resevoir. So...look at the fluid to see if it is overfilled. Secondly, I would crack the bleeders on the system to see if there is any air in the system. Next, if that doesn't take care of things I would examine the master cylinder. It could be weak.
Nov 8, 2006 at 10:16 AM
