Battery Question: Honda Stream
HONDA
AMERICUS
Hi all,
I have a Honda Stream, 2003 with about 15,000 miles on it.
1st question: How long should a battery normally last? 2 years? 5 years?
2nd question: I went on vacation for two weeks, came back and the battery was dead. I jump started it and everything was fine. A few months later I went on vacation for 3 weeks, but had someone start the car once a week for about 5 minutes. My friend said that the 2nd or 3rd time that he tried to start it, it was dead.
Now, if I don't start the car every 2 or 3 days, the battery dies. I took it to the Honda Dealer and they checked the battery. They said it was at 70% and it was fine. One mechanic said that with all the electronics in the car, it needs to be started once a week. Another mechanic (at the same garage) said it needs to be started every 2-3 days. They also recommended unplugging the battery when I go on vacation.
So, do I just need to replace the battery? Can I put in a bigger battery?
Thanks,
Phil
Mar 16, 2006 at 1:47 AM
BRUCE HUNT
  • 3,754 POSTS
Depends on the battery as they are usually engineered very well and last just beyond the warranty period. So a five year battery should last 5 to 6 years.
It should last longer than that, but with the alarms, radio, clocks, etc there is a draw. Now the size of the battery is something you have to play by ear. I would definetly go with the biggest boy out there and I would suggest staying away from the Walmart everstart batteries. I have used them and found them to be an inferior battery. Just my opinion. I use one in my boat or camper but when it comes to my car I put in a good battery from a reputable place. I do like the diehard and KMart sells that now.
Mar 20, 2006 at 3:07 PM
AMERICUS
Thanks Bruce.
I ended up taking it back to the dealer (after it died again), and putting in a new battery. The warranty on it was only 20 months, so I was stuck with the bill. Also, they wouldn't let me put in a larger battery.
I'm going to keep an eye on the battery, and see if it dies after sitting for a few days. If so, I'll take it back to the dealer and see if they can do a check on the electronics/alternator, etc.
--Phil
Mar 21, 2006 at 1:31 AM
