Axle not spinning/Not stalling
HONDA
EVO
I'm currently done with replacing my tranny for my 93 hatchback si. I had put everything back into place. I started the car fine, but my passenger side axle wasn't spinning on it's own. What do you think is the problem? I changed the speed thing, but it's still the same. Another question is.. When I put it into first gear and let go of the clutch nothing happened.. it didn't stall? Why didn't it stall?
Jan 31, 2007 at 7:46 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
no offense intended, but are you sure you installed the tranny right, second the clutch did not engage when you put it in gear, I would check to make sure the tranny is installed and hooked up right., do you have a repair manual that might help you with the installation.
also did you replace your tranny with new or used, if you replaced it with a used one that one might be bad
Jan 31, 2007 at 8:01 AM
