2005 Honda Odyssey srs light
2005 HONDA ODYSSEY
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
HSNITZ
I've found out how to reset the srs light on the internet, but I can't find the mes connector on my odyssey.
Aug 23, 2010 at 4:16 PM
WRENCHTECH
  • 20,761 POSTS
You can't read codes on this vehicle without a factory scan tool. they are read right through the OBD2 data link connector.
Aug 23, 2010 at 6:16 PM
HSNITZ
I think you may have responded to the wrong question. I'm just looking for the mes location, or am I missing something? Thanks.
Aug 24, 2010 at 7:04 AM
KHLOW2008
  • 41,814 POSTS
Hi hsnitz, Hope the diagram is helpful.
https://www.2carpros.com/forum/automotive_pictures/192750_SRSComponent05OdesseyFig01_1.jpg
Aug 24, 2010 at 8:20 AM
HSNITZ
...thanks. I'd found the region, though, just don't know which connector it is. Why I asked if it's always yellow. Is there an easy way to identify the beast?
My plan then, assuming the procedure is the same as on earlier models (resetting using a paper clip, etc), I would try that. Sound okay?
Thanks again...you guys are great!
Aug 24, 2010 at 10:58 AM
KHLOW2008
  • 41,814 POSTS
It is yellow and plugged into the fuse box. The manual erasing procedure is similar to earlier models.
https://www.2carpros.com/forum/automotive_pictures/192750_MES05OdysseyFig34_1.jpg
Aug 24, 2010 at 11:31 AM
