Electrical problem
2005 Honda Odyssey 6 cyl Automatic 115000 miles
My interior map light stopped working with the door open option, although you could still manually turn it on. Then a week ago, it quit working all together. I checked the bulb, replacing it with a new one and the other "working" one, and also checked the fuse which I found worked with the other map light. Light still does not work, could it be on a seperate fuse under the hood, or is there some other "easy" fix that I might try next?
Aug 16, 2010 at 11:37 PM
