2004 Honda Odyssey timing belt
2004 HONDA ODYSSEY
ITSMEFROMIOWA121
Engine Mechanical problem
2004 Honda Odyssey 6 cyl Front Wheel Drive Automatic 144 k miles
To repair the timing belt, do they have to take out my cylinders, send them to another company to set the timing and in all, should it cost about $4200.00?
Aug 20, 2010 at 10:01 PM
HONDA TECH 1818
  • 536 POSTS
If the timing belt breaks then they have to remove the cylinder heads out to inspect the valves.
You don't need to remove the cylinder heads if you are only replacing the timing belt.
Aug 20, 2010 at 10:26 PM
