Replacement steps for power mirror is below..let me know if you have manual mirrors instead as steps may differ...
Remove the mirror mount cover, as follows:
Lower the door glass fully.
Carefully pry out the mirror mount cover by hand.
Disconnect the negative battery cable.
Remove the inner handle, as follows, being careful not to scratch the door panel:
Pry out the cap and remove the screw.
Pull the inner handle forward and out halfway.
Disconnect the inner handle rod and power door lock switch connector (if equipped).
Detach the clips and hooks, then remove the speaker grille. Remove the screws.
Remove the pull pocket panel (A), as follows, being careful not to scratch the door panel:
Release the hook and detach the power window switch connectors.
Release the clips that hold the door panel (A) with a commercially available trim pad remover (B), then remove the door panel by pulling it upward. Disconnect the speaker connector (C).
On 2002-04 models equipped with seat heaters, disconnect the seat heater switch subharness connector.
NOTE
Remove the door panel with as little bending as possible to avoid creasing or breaking it.
Disconnect the connector (A), and detach the harness clip (B), then remove the bolts securing the mirror. While holding the mirror (C), push out the clip (D), and remove the mirror. Be careful not to scratch the door.
To install:
Install the power mirror in the reverse order of removal, and note these items:
Make sure the connector is plugged in properly.
Attach the harness clip.
Push the cover clip into place securely.
Install the door panel in the reverse order of removal, and note these items:
Replace any damaged clips.
Push the clips into place securely.
Make sure the connectors are plugged in properly, and the inner handle rod is connected properly.
For 2003-04 models, reset the power window control unit, as follows:
Turn the ignition switch off, then back ON (II).
Move the driver's window all the way down by holding the driver's switch to the AUTO DOWN position; when the window reaches the bottom, hold the driver's window switch in the AUTO DOWN position for 2 seconds.
Move the driver's window all the way up without stopping by holding the driver's switch to the AUTO UP position; when the window reaches the top, hold the driver's window switch in the AUTO UP position for 2 seconds.
If the window does not work in AUTO, reset the power window control unit according to the above procedures again.
On 2002-04 models, if equipped with seat heaters, check for proper operation.
Check the window and power door lock operations.
Jan 25, 2010 at 3:46 PM
