Here are additional info you requested.
DRIVER'S SWITCH PANEL REMOVAL
NOTE:
When prying with a flat-tip screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
Take care not to scratch the dashboard and related parts.
Gently pull out on the driver's switch panel (A) to release the right clips (B), then detach the remaining clips (C). If equipped, disconnect the cruise control main switch connector (D), TCS switch connector (E), power mirror switch connector (F) and power sliding door switch connector (G), then remove the panel.
CENTER PANEL REMOVAL
1. Remove the steering column covers
2. Carefully detach the clips, then remove the center panel (A). Disconnect the heater control panel connectors (B) or climate control unit connectors, rear A/C control dial (C) (for some models) and interior light switch connector (D). With navigation system, disconnect the hazard warning switch connector, rear A/C control dial, and interior light switch connector. For '03- 04 models: Disconnect the passenger's airbag off indicator connector.
Apr 3, 2009 at 8:19 AM
