The lights are powered through two separate circuits. The CHMSL light is a direct feed from the brake light switch which shows the switch, fuse and it's wiring is good. However the body mounted lights use a feed from the switch that goes to the brake light failure sensor. That is fed from a different fuse (fuse 9) and controls the lights based on the power and the brake switch position. To test the system you need to access the brake light sensor. It is located behind the drivers side rear trim panel just inside the rear hatch. The first test is to unplug the connector on the module, then turn on the key, the light in the dash should stay off. Next with the connector unplugged you can take a test light and check for power at the Yellow wire on pin 5 with the key on then with the brake pressed test for power at the White w/black stripe wire on pin 6 If you have power on both of those the next test is to check the ground wire on pin 3, To check it you can use the test light and connect it between pins 5 and 3. With the key on it should light, if it doesn't the Black ground wire to the chassis is corroded or broken. The last test is to use a jumper wire between the Yellow wire on pin 5 and the Green wire on pin 2, with the key on the lower brake lights should come on if the wiring to them is OK. If those tests all show the various things as they are supposed to be the light warning module is bad and needs to be replaced. Or if you don't really care to know if there is a brake light problem you could replace it with a simple relay connect up as a replacement. For that you could wire a relay as shown in the last image. That would take the switch signal and turn on the relay which would then close the circuit for the brake lights. However you would lose the light warning on the dash.
Dec 8, 2020 at 7:51 AM
(Merged)
