2002 Honda Odyssey TIMMING BELT REPLACEMENT
2002 HONDA ODYSSEY
JULIO RAMIREZ
Engine Performance problem
2002 Honda Odyssey 6 cyl Front Wheel Drive Automatic 98K miles
I HAVE RE-INSTALLED THE TIMMING BELT 3 TIMES AND THIS VEHICLE STILL TREMBLES/SHAKES A LITTLE. THE BELT IS OFF BY A TOOTH. WHAT AM I DOING WRONG? DO I NEED TO CHANGE THE BELT TENSIONER EVENTHOUGH IT IS NOT LEAKING? WHAT CAN I BE DOING WRONG OR NOT PAYING ENOUGH ATTENTION TO?
Sep 23, 2008 at 9:15 AM
KHLOW2008
  • 41,814 POSTS
HI Julio Ramirez,
You mentioned the belt is off a tooth, so how is it now?
After installation. did you turn the engine by hand a few times and reconfirm marking. DO NOT turn in reverse direction.
We start from here.
If the tensioner pressure is weak, it should be replaced.
Oct 10, 2008 at 6:07 PM
