Could the fuel pressure regulator cause the van to stall only when first taking off. It seems the fuel line gets air in it when the engine is off for a few minutes. When you start it and try to take off right away, it sputters a bit; after that it runs get. Is there a check valve of sorts. Note: this problem started to appear occassionally after the transmission was rebuilt and an oxygen sensor changed. The transmission company said it is not their problem.
Nov 19, 2009 at 10:59 AM
