2001 Honda Odyssey noisy
2001 HONDA ODYSSEY
200,000 MILES • 6 CYL • FWD • AUTOMATIC
CARASHRAF
hi, my van makes grinding noise while making left turn. i happened to put her on the jack stand to observe from where the noise generates. as i shifted on drive the left wheel start spinning but right wheel barely spins.
is that normal? or right axle gone bad. it does not make any noise while driving straight.
please let me know.
thanks
Jun 22, 2008 at 10:25 AM
KHLOW2008
  • 41,814 POSTS
Hi carashraf,
If you spin the right wheel by hand and it starts moving, it should be ok. If it is tight, then you need to check the brake caliper and slider bolts.
When making a turn, the wheels would be leaning a little so if the backing/cooling plates near the lower arm is too near the rotor, it would be scraping against it.
Make sure you have enough clearance.
Jun 22, 2008 at 11:00 AM
