2001 Honda Odyssey leak of transmission fuild and sliping g
2001 HONDA ODYSSEY
168,000 MILES • 6 CYL • FWD • AUTOMATIC
EQAMAR
I recently had my transmission overhaul and rebuilt in my honda odyssey 2001. It slipping the gear while driving and didn't not pickup speed after breaking. Transmission fuild is also leaking, but don't know from where. It look like that fuild is heated and come out, please suggest the solution.
Regards,
Jul 10, 2008 at 5:04 AM
SERVICE WRITER
  • 9,123 POSTS
Obviously don't drive it like that. I suggest calling the shop that rebuilt it and have it towed there for them to look at it. IT may be a situation that may be on their end for responsiblity, such as a line left loose or what have you. You'll burn up the tranny running on low fluid. Try to be there when they look at it and have them show you the leak. IF you go after this yourself, it may be an out for the shop to question what happened should you attempt a repair yourself.
Low fluid burns up trannys.
Jul 10, 2008 at 5:36 AM
