2001 Honda Odyssey CAR ALARM WON'T STOP AND BATTERY IS LOW
2001 HONDA ODYSSEY
100,000 MILES • 6 CYL • FWD • AUTOMATIC
BONSON
  • 6 POSTS
Hi
My Honda odyssey van was sitting for about 2-3 weeks without being moved. I thought I would go out and start it because it had been unused for so long.
The remote would not open the door, in fact, the alarm started to go off when I tried the remote. I then opened the door manually but the alarm would still not be silent. I can tell the battery is low because the alarm sound is weak and slows when I open and close the door.
The ignition is dead because the alarm is going. Panel lights come on but are dim, clock still goes but at wrong time.
I cant jump start the battery because the car is immobile because the alarm disarms stuff.
I have Googled and tried advice like turn the key left then all the way right and that should turn the alarm off - doesn't work. I have looked for the small button meant to be at knee level to turn off the alarm - cant find it.
Not sure if it is factory fitted alarm or after factory fitted.
To cut all that story short - how do I disconnect the alarm - thanks so much.
Kim Johnson
Nov 15, 2009 at 6:01 PM
HONDA TECH 1818
  • 536 POSTS
When the alarm go off, is the horn honking or aftermarket siren sounds?
Nov 15, 2009 at 11:15 PM
BONSON
  • 6 POSTS
It was more like a chirping sound. I think it is the horn but the battery is low.
Thanks
Nov 17, 2009 at 9:39 PM
HONDA TECH 1818
  • 536 POSTS
Look under the driver's side dashboard near the parking brake and brake pedal area to see if theres any aftermarket components. You could use a battery jumper or jump start the battery and try to disarm the system by pressing unlock on the remote.
Nov 18, 2009 at 1:01 AM
BONSON
  • 6 POSTS
Hi again I have found out that the alarm is after factory. The remote is not Honda issue. The system closes all windows when the remote is closed. So the noise is not the horn. I have looked where you said and can't see anything that would indicate alarm, but I have taken 3 pics of the are and you may be able to spot something. Thanks
https://www.2carpros.com/forum/automotive_pictures/435511_P1010035_1.jpg
https://www.2carpros.com/forum/automotive_pictures/435511_P1010036_1.jpg
https://www.2carpros.com/forum/automotive_pictures/435511_P1010037_1.jpg
Nov 18, 2009 at 11:14 AM
HONDA TECH 1818
  • 536 POSTS
There's a couple of big wires (red) and the black wires is not factory at the right side of the picture. The aftermarket security system could be inside the kick panel just follow the red wires to see where it goes.
Nov 18, 2009 at 10:19 PM
BONSON
  • 6 POSTS
Gee you are good. How you manage to notice that? The wires go to a box under the driver seat. I didn't even know the box was there. I have given more pics. Will I disconnect all wires to this box? The guy who sold this van said he did several add ons. I don't care if I lose his add ons. I only want the alarm cut, but I don't want to disarm anything that I need to get the car up and running. If this is the alarm I suppose I will be able to hook up the box and alarm after the van has been jumped and the battery is good again. Thanks again.
https://www.2carpros.com/forum/automotive_pictures/435511_P1010038_1.jpg
https://www.2carpros.com/forum/automotive_pictures/435511_P1010039_1.jpg
https://www.2carpros.com/forum/automotive_pictures/435511_P1010040_1.jpg
Nov 19, 2009 at 5:12 PM
HONDA TECH 1818
  • 536 POSTS
I repair Honda cars for years and know the ins and outs of their automobiles.
The second picture you provided is a power inverter, which could drain your battery because it is hooked up directly from the battery. This device has nothing to do with your no start.
Check the following places to see if you can find any aftermarket device:
The first picture on the left side is the kick panel (gray) - remove it to see if you could find anything there...
What about the two black wires next to the red wires, where do they go?
Check the area above the two red wires...
Nov 21, 2009 at 12:02 AM
BONSON
  • 6 POSTS
Sorry been so long getting back to you. I have been looking at places you mentioned but am still stumped. I have taken more pics because I still don't know what I am looking for. The pic with the 3 switches are all switched on. One of the switches looks like it has different wire and electrical tape which could be an add on. The black wires seem to go in different directions. If I follow a suspect wire what am I looking for at the end of it? Sorry for being so stupid and I appreciate all your help. - Thanks again. A
https://www.2carpros.com/forum/automotive_pictures/435511_P1010049_1.jpg
B
https://www.2carpros.com/forum/automotive_pictures/435511_P1010050_1.jpg
C
https://www.2carpros.com/forum/automotive_pictures/435511_P1010051_1.jpg
D
https://www.2carpros.com/forum/automotive_pictures/435511_P1010052_1.jpg
E
https://www.2carpros.com/forum/automotive_pictures/435511_P1010053_1.jpg
F
https://www.2carpros.com/forum/automotive_pictures/435511_P1010054_1.jpg
G
https://www.2carpros.com/forum/automotive_pictures/435511_P1010055_1.jpg
H
https://www.2carpros.com/forum/automotive_pictures/435511_P1010056_1.jpg
I
https://www.2carpros.com/forum/automotive_pictures/435511_P1010057_1.jpg
Dec 5, 2009 at 5:16 PM
HONDA TECH 1818
  • 536 POSTS
The picture A- the two swtiches (black and white wires) on the left side looks like one of those is the switch to turn off the alarm. Try turning the ignition key to on and switch the switch to off and see if the alarm would turn off.
The picture E- The alarm shock sensor is on the left side (black box) if you follow the shock sensor wires you might found the alarm (black box also but bigger).
Dec 6, 2009 at 11:17 PM
BONSON
  • 6 POSTS
I have just managed to get back to the problem after months. Have had other problems - so sorry.
None of the switches turned off the alarm.
I eventually got a jump start. Before I could jump I had to stop alarm. I could only use the remote once juice was going into battery. Once remote turned off alarm, the car started easily with jumper cables.
The alarm sensor you talk about is an AudioVox Model AS-9495-4P Shock Sensor.
I was wondering if I disconnected wires from the box it would disable the alarm.
Also, once I jumped, I let the van run about 5 minutes, turned off the engine and tried to restart. All the panel lights came onl, which they didn't before when the battery was dead, but the key didn't start the engine again. Just silence. Then the alarm started again. So I jump started the car again.
I have had it running for about 30 minutes this time and just turned it off. It restarted very sluggishly, so I have got it running again to try and boost the battery.
I also topped up battery cells with distilled water before the jump. The cells were pretty low.
Is the alarm forever pulling power from the battery? If I could disarm it, I would have a better chance of recharging battery.
I don't think I will reconnect it. It seems to be such a drain on the battery.
Once again, sorry for taking so long to reply. I appreciate your help.
Feb 3, 2010 at 12:01 PM
