2000 Honda Odyssey Transmission leaking
2000 HONDA ODYSSEY
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHARLES KIM
Driving on FWY, I saw white fumes from the hood. I also felt rubber-burning smell. I pulled over onto the shoulder of the freeway. During towing my car, towing person found leaking from the trasmission.
Later I found multiple transmission oil drop marks on the left side of the driveway. Opening the hood, I also saw oil-wet trace over the left side(beside the battery seat) engine part.
For reference, aprx. 2 months ago, I had transmission oil replaced: the mechanic washed the transmission with transmission oil many times; repeated being filled & drained for over 2 hours.
Jun 3, 2010 at 12:24 PM
KHLOW2008
  • 41,814 POSTS
Hi Charles Kim,
You would need to clean up, check the fluid level and then start vehicle to locate the leak. It could be a burst hoses or excesive fluid in the trans causing the fluids to be pushed out of the breather tube.
Jun 3, 2010 at 12:57 PM
