2000 Honda Odyssey Knocking
2000 HONDA ODYSSEY
137,400 MILES • 6 CYL • 2WD • AUTOMATIC
TARHEELS20
  • 4 POSTS
I have a question for the aboved vehicale. I was driving along and all of a sudden the van make a noise and then shut off. When we got it running again it starts to knock and then when it gets under 1500 rpm it shuts off. All the fluids r good. Could u know what could cause this>
Apr 22, 2009 at 3:58 PM
Is the oil full? Also, can you tell where the knock is coming from?
Apr 22, 2009 at 5:06 PM
TARHEELS20
  • 4 POSTS
sorry
Apr 22, 2009 at 5:31 PM
TARHEELS20
  • 4 POSTS
[quote:46fc5ed152="Jacobandnickolas"]Is the oil full? Also, can you tell where the knock is coming from?[/quote:46fc5ed152]
- Yes the oil is fulll still have 300 miles till next oil change of 2 months. Its making the knocking noise in the upper front of the engine
Apr 22, 2009 at 5:37 PM
If it is the upper front, I would start by checking the timing chain / belt.
Apr 23, 2009 at 12:12 PM
TARHEELS20
  • 4 POSTS
[quote:39f6f95223="Jacobandnickolas"]If it is the upper front, I would start by checking the timing chain / belt.[/quote:39f6f95223]
I have had the timing belt changed along with all of the other belts, also I had the water pump replaced and all of the spark plugs.
Apr 23, 2009 at 4:22 PM
Was this just done? I question if the belt tensionier has gone bad. That is why I suggested starting there.
Apr 23, 2009 at 8:08 PM
