I just had a AC prob. It stopped cooling and starts to overheat if the AC is lturned on. On popping hood, the passenger's side fan is NOT working (it used to when AC was on). I went foolishly into trying to change the fan out without checking if it actually ran (any info on how to check either with Vmeter or jumping the 12 V into the connector)? Also, I found the relay (I think) for the AC under the cruise control ... any way to check that? Assuming it is the fan, how do you get the fool thing off without taking off the radiator. I originally thought that the thermostat was sticking causing the AC to stay off ... changed thermostat, flushed and filled the radiator. I spent about 2 hours pulling stuff off trying to get the fan off and about an hour putting it all back with no success. It has now become a issue of price (sighs heavily). Any help much appreciated.
Jun 10, 2008 at 1:52 AM
