2000 Honda Odyssey gear shift not lock in park
2000 HONDA ODYSSEY
245,000 MILES • 6 CYL • FWD • AUTOMATIC
CALLSIGN
  • 7 POSTS
Not sure if this is the right category. I recently bought this privately, I notice that the gear shift does not lock when in park, I do not have to press brake to take out of park, can you direct me to the area to correct, is there a switch on the brake or how does this work
Nov 29, 2009 at 11:57 PM
HONDA TECH 1818
  • 536 POSTS
There's a shift lock solenoid inside the gear shifter, it is located inside the steering column. Do you hear a click when you press on the brake pedal?
Nov 30, 2009 at 1:07 AM
CALLSIGN
  • 7 POSTS
Yes, I hear a click when I step on the brake to shift out of park
Dec 3, 2009 at 6:01 PM
HONDA TECH 1818
  • 536 POSTS
The shift lock extension could be broken, remove the steering column covers and inspect the gear shifter components. Most likely you will need a new shifter assembly.
Dec 4, 2009 at 1:01 AM
