2000 Honda Odyssey Engine cutting out
2000 HONDA ODYSSEY
144,000 MILES • 6 CYL • FWD • AUTOMATIC
NATHANR
I was driving in heavy rain last night and my engine cut out about 8 times in a 1 mile stretch. If i put the car in Neutral it would start back up, it would drive fine for a couple hundred feet and cut out again. I noticed the TCS (traction control system) light came on when the car would die out.
I drove the car today about 20miles and the engine ran fine.
The new codes from the computer were P1366 P1361 and a code that has been showing for along time P0420.
Oct 26, 2008 at 3:57 PM
KHLOW2008
  • 41,814 POSTS
Hi Nathanr, P1361 and P1366 are faults transitted by the TDC sensor 1 and 2. Based on your description, while in heavy rain , water is splashed onto the sensors giving a false reading and the cutting out. I would suggest checking the connetors for water contamination and cleaning them with application of dielectric grease to prevent oxidation which would cause the sensor to fail at a later date.
https://www.2carpros.com/forum/automotive_pictures/192750_TDC1n200Odyssey_1.jpg
P0420 means the catalytic converter is not in good condition and would require replacement.
Nov 29, 2008 at 9:11 AM
FAHD6969
thank you for such a great solution. i had both codes which I suspected something weird happened especially after having the car parked for 3 days in the rain and humidity. pulled the plugs and sprayed them with the dielectric cleaner and it worked. thank you thank you
May 27, 2015 at 7:54 PM
