2000 Honda Odyssey Cruise Control
2000 HONDA ODYSSEY
186,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATRIXGURU123
Someone was trying to open the automatic sliding door at the same time I was locking the car. The door quit working which turned out to be blown fuses. Every since this happened the Cruise control will not set. The cruise button on the dash (left of steering wheel )lights up when pressed but the cruise will not set. I have checked the fuse but not blown . Local Honda dealership does not know what is wrong. Can you tell me some things to check\replace?
Oct 27, 2010 at 12:13 PM
KHLOW2008
  • 41,814 POSTS
Hi matrixguru123,
Which door was it that caused the problem?
Is the door operating correctly now?
Is there any other components that is not working correctly?
Is any warning indicator showing?
Most common faults for cruise control are :
1. Faulty brake switch.
2. Bad cable reel under steering wheel.
Oct 28, 2010 at 1:50 PM
MATRIXGURU123
The right passenger cargo door. It is working correctly now. Everything else works normally.
There are not indicators showing.
Oct 28, 2010 at 1:57 PM
KHLOW2008
  • 41,814 POSTS
You would have to perform test to find out what is causing the problem.
Brake switch has 2 circuits, one for the brake lights and the other for the cruise control. When brake pedal is not depressed, the the cruise control circuit must have continuity whereas the brake circuit should not have any. When brake pedal is depressed, the situation reverses.
Check the brake switch to pedal clearance adjustment, excessive clearance would cause the cruise control circuit to be open.
Oct 28, 2010 at 2:00 PM
MATRIXGURU123
Is this the switch that the pedal rest against so when pressed you can remove from park
Oct 29, 2010 at 7:37 AM
KHLOW2008
  • 41,814 POSTS
Yes, that is the switch.
Oct 29, 2010 at 8:24 AM
KATHI CASSADY
  • 6 POSTS
My cruise control would not stay on when I took my finger off of it. The cruise control switch had to be replaced. Labor $60.60, Switch $203.79. Works fine now. Kathi
Jun 19, 2024 at 8:02 AM
Excellent addition to this thread! Please feel free to use 2CarPros anytime!
Jun 19, 2024 at 11:16 AM
