Computer reset
2000 HONDA ODYSSEY
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHILLY48
hi, i have a check light on my van, so the computer needs resetting. how do i change this?
Sep 4, 2009 at 10:16 AM
HONDA TECH 1818
  • 536 POSTS
Did you fixed the problem, or you just want to clear the check engine light, you can disconnect the negative battery terminal for 10 seconds and reconnect or you can clear it with a code scanner.
If there is a problem with your engine the CEL will come back on.
Oct 18, 2009 at 11:33 PM
KLEONLOVE2008
2000 Honda Odyssey . The coolant temperature gauge going up is ignition turn on
Oct 16, 2020 at 7:28 AM
Please post your new question here, you must be logged in.
Oct 16, 2020 at 11:38 AM
