We have a 99 Honda Odyssey EX. Tranny was replaced for the second time at 142K miles. Comes with a 3 year / 36K mile warranty. We hit a deer a couple months back after the tranny was replaced. Repairs included radiator along with headlight and grill and hood. Bumper painted.
About one month ago the tranny cooler line inside radiator failed along with the radiator. Almost all radiator fluid ran out before my wife got home from work. It had a reddish milky look to it, so I knew that it must have had a tranny cooler line fail in the radiator. Had body shop tow van and replace radiator and flush both coolant system and tranny.
All seemed OK until New Year's Eve day on a day trip to a local state park about 30 miles away. Final approach to the park requires driving about 2-3 miles up a steep incline. Tranny quit functioning about 3/4 of the way up the incline. Had none of the 4 forward gears or reverse. Had to coast backward down the narrow road in neutral to the bottom and turn around at the only side road and then forward coast it to the side of the road.
Tranny was hot but fluid was full. Let it set about 1 hour and it again functioned OK. Drove it home without incident. I inspected the coolant reservoir and it had some left over tranny fluid in it in the bottom of it. Also looked at the tranny fluid on the dip stick and it looked what I would recognize as normal red. Took it to the body shop for them to clean out the coolant reservoir before I took it to Honda dealer.
Honda dealer took the car and provided us a loaner. called me shortly after and told me I had tranny fluid in the coolant and coolant in the tranny. I told them what occurred and the tech immediately gave me the boiler plate response of "who knows what damage that caused and he did not feel the warranty would be honored". He also would not give me a definitive answer whether getting coolant in the tranny could lead to any kind of tranny issue.
Also, something to note, which you probably already know, is the 99 thru 2004 Odysseys have had lots of tranny failures and multiple replacements like ours.
Took car back to body shop and had them flush both the coolant system and the tranny and it seems to be functioning OK.
So, my question is whether or not any tranny issue of any kind could result from temporarily having coolant mixed with the tranny fluid?
Thanks a lot - Egghead
Jan 4, 2008 at 3:36 PM
