1999 Honda Odyssey Lucas Transmission Fix, How can I put in
1999 HONDA ODYSSEY
MOLSONCANADIAN
  • 81 POSTS
Transmission problem
1999 Honda Odyssey 6 cyl Front Wheel Drive Automatic 165kms miles
Hi there, I recently purchased Lucas Transmission Fix from my local store for 10 bucks, and I want to put in my Odyssey. The thing is that when the tranny is put on reverse, just before letting off the brakes, there's a mild bang. So I thought 10 bucks of oil additive couldn't hurt. So the other thing is, the dipstick displays just a bit more oil than high position, so I'm afraid that if I put in more oil, then CE light will come on for too much oil. How do I get the oil out without draining from underneath?? Is it extractable through the dipstick or something?
Or can I just pour it in, disregarding the already too much oil in the tranny?
Thanks, even though dumb question.
Oct 21, 2010 at 4:17 PM
CARADIODOC
  • 34,306 POSTS
Hi molsoncanadian. Welcome to the forum. For the symptom you described, "mechanic in a can" is most likely not going to help, but depending on the type of additive, it could help to keep rubber seals and gaskets pliable so they work better. Any type of bang or thud is a mechanical issue. While that could be caused by abrupt engagement of one of the clutch packs inside the transmission, a more common cause would be a rear drum brake sticking, often due to minor rust buildup overnight from humidity in the air. When that is the case, the problem occurs when the vehicle is first driven in the day, and does not occur later.
Loose or worn steering and suspension parts cause banging noises too. Another common cause is worn engine mounts, particularly on front-wheel-drive vehicles with engines that sit sideways. There are two metal parts separated with a rubber isolator. When that rubber isolator deteriorates, the metal parts hit each other, most often when changing between forward and reverse.
As for removing transmission fluid, there are suction devices that look similar to a grease gun but they have a pull handle on the end instead of a lever. The tube is inserted down the dipstick tube. A little extra fluid isn't going to cause a problem and that is not something that is monitored directly by the Engine Computer. (He's the guy who turns on the Check Engine light). When the Check Engine light turns on, it means the problem that was detected could have an adverse effect on tail pipe emissions. Overfull transmission fluid won't affect emissions, but severely overfull fluid, like a quart or two, could cause slipping and shifting problems. This is hydraulic fluid and is not meant to compress. Overfull fluid can get so high it hits rotating parts and gets air whipped into it. Air does compress so the fluid won't be able to do what it is supposed to do. That is apply pressure on the clutches to engage them and push the various shift valves around to different positions.
Be sure you're checking the fluid level with the engine warmed up and idling after you run the shifter through all of the gears. That fills up all of the passages with fluid. All automatic transmissions will read overfull when the engine is not running.
caradiodoc
Oct 21, 2010 at 6:06 PM
MOLSONCANADIAN
  • 81 POSTS
[quote:07e1f6f087="caradiodoc"]Hi molsoncanadian. Welcome to the forum. For the symptom you described, "mechanic in a can" is most likely not going to help, but depending on the type of additive, it could help to keep rubber seals and gaskets pliable so they work better. Any type of bang or thud is a mechanical issue. While that could be caused by abrupt engagement of one of the clutch packs inside the transmission, a more common cause would be a rear drum brake sticking, often due to minor rust buildup overnight from humidity in the air. When that is the case, the problem occurs when the vehicle is first driven in the day, and does not occur later.
caradiodoc[/quote:07e1f6f087]
The last 2 sentences sure helped alot. I thought the transmission would need draining since it says overfull when engine off. Thanks mate.
Oct 21, 2010 at 7:14 PM
MOLSONCANADIAN
  • 81 POSTS
caradiodoc, thanks for the guidance, I poured in half the bottle and noticed a smoother tranny. I am going to pour the rest in today. I wonder how long this stuff will keep the tranny smooth. thanks lots.
https://www.2carpros.com/forum/automotive_pictures/547759_3139_1313_large_1.jpg
Oct 24, 2010 at 1:02 PM
CARADIODOC
  • 34,306 POSTS
Engine oil additives such as anti-foaming agents, corrosion inhibitors, detergents, and friction modifiers break down in about 3,000 miles; less if they get really hot. Cooling system additives like rust preventers and water pump lubricant break down in about two years. Coolant is alcohol and that doesn't change over time, but it is replaced every two years to get rid of the acids that normally develop.
Transmission fluid is a little different. Its additives last a lot longer. Under normal driving conditions the fluid does not need to be replaced so often. Exceptions would again be from overheating. While its main purpose is as a hydraulic fluid that transfers pressure and makes things move, it must also lubricate, (isolate moving parts from each other), and keep seals soft. Plowing snow and pulling a trailer put extra strain on the fluid in two ways. Main line pressure increases as throttle position increases. That means the pump works harder generating higher temperatures. The higher pressures are applied to the clutch packs to prevent them from slipping under the increased engine torque. Secondly, a harder-working engine transfers more power through the torque converter between the engine and transmission. That is where most of the heat is generated. To reduce the heat buildup, there is a cooler built into the radiator to transfer heat to the coolant, and almost all cars now have a "lockup torque converter" to eliminate the inherent slippage. That reduces heat buildup and improves fuel mileage. External coolers can be added too.
Chrysler was the first to develop a lockup converter and used it in 1977. I have a 1978 model and had a lot of trouble with that system. Now that it is perfected, only GM had a huge problem with the unit sticking on their '80s models front-wheel-drive cars. The solution was to unplug the electrical connector so it never activated, therefore it couldn't stick. When it did stick, it caused engine stalling at stop signs just like forgetting to push in the clutch pedal on a manual transmission.
Chrysler was also the first to use a completely computer-controlled automatic transmission starting with the 1989 models, and like anything new, they had a lot of trouble with it. By now every company has developed their own version and has gone through the same problem and learning phase. I still use a 1988 Grand Caravan to pull an enclosed trailer that's bigger than the van. I have the older non-computer-controlled transmission and the fluid and filter has only been changed once in 222,300 miles. I don't propose anyone abuse their vehicle like that, but it goes to show that transmission fluid is some really tough stuff.
A friend solved a harsh engagement problem by adding an additive to his high-mileage transmission a few years ago. He had one of the few Chrysler units that made it to 180,000 miles without needing a rebuild. Most of these additives work the same way by dissolving varnish buildup on valves and by softening hardened rubber seals. I've heard of a number of cases where people use these products, but what I haven't heard is people needing to keep adding more periodically. That would seem to indicate you can expect it to last quite a while. At 165,000 miles and 11 years old, the seals can start to get hard and won't conform to surface irregularities like they did when they were new. For proper maintenance, this additive should not be an alternative to regularly-scheduled fluid and filter changes. When that is done the next time, see how it shifts before you add more of this product. The higher-cost services are now adding a bottle of strong detergents to the fluid first to dissolve the varnish buildup, then after driving it a few miles, they completely drain the system and put in all new fluid. You might not need an additive as they include their own bottle of additive with the new fluid. The reason this high-cost service has popped up all over is because transmission problems have become very common with newer cars and people seem to think that's normal. Adding a product like you're using will address those problems related to varnish causing sticking valves, and seals that might be leaking internally. Many transmission problems are caused by broken parts. No additive is going to solve that.
caradiodoc
Oct 24, 2010 at 2:43 PM
