how can i replace the computer
1999 HONDA ODYSSEY
ISHKING54667
Transmission problem 6 cyl Two Wheel Drive Automatic 160000 miles
Im having trouble with the computer in the transmission and i need a way to replace it. please send instructions to repair
Dec 5, 2009 at 3:30 PM
KHLOW2008
  • 41,814 POSTS
Hi ishking54667,
There are no computers in the transmission. All solenoids are on the external of the transmission. The computer for the transmission is the same as the engine computer and is located inside vehicle.
What is the problem that you are facing?
Dec 6, 2009 at 9:17 AM
RONGOLD
hello I have similar problem where vans drives normal for about 1/4 mile and then acts like it goes to neutral have to stop the engine and restart put back in drive and go again next 1/4 mile, fluid ok disconnected battery and still same problem any ideas?
Feb 19, 2018 at 7:11 AM
It sounds like you have a input shaft speed sensor going out. I would start by checking he fuses and run the codes first so we don't chase our tail.
and
Check out the fuse panel and ECU locations diagrams (Below)
Feb 21, 2018 at 10:51 AM
