1998 Honda Odyssey spark plug problem??
1998 HONDA ODYSSEY
13,000 MILES • 4 CYL • FWD • AUTOMATIC
DOBERGAL27
Hi
My car doesn't start all the time. It turns over really well and I smell gas (trying not to flood it) however it is not firing. IF it does start it runs smooth. It is only after it has been shut off then I try to start it again.. it will sit there and turn over. It seems like there is no spark. My question is... Wouldn't it run rough if it were the spark plugs??? Could it be the fuel pump.. even tho I do smell gas.
Sep 15, 2008 at 9:21 AM
KHLOW2008
  • 41,814 POSTS
Hi dobergal27,
You need to verify if it is spark or fuel relate.
However if it is intermittent, I would suggest you check the PGM-FI main relay.
Oct 10, 2008 at 5:35 PM
