1996 Honda Odyssey valve timing marks
1996 HONDA ODYSSEY
UNDERDOG45
Engine Mechanical problem
1996 Honda Odyssey 4 cyl Front Wheel Drive Automatic
Helping a friend with his timing belt replacement.....the book is showing obscure timing marks.......so far we have the camshaft set where the valves of number 1 cylinder are closed. If we then set the crank pulley with keyway pointing up, will that be correct timing? So far, our settings have produced zero compression at number 1 cylinder. The engine ran ok before.......water pump was bad. Help!
Jul 11, 2008 at 3:15 AM
MHPAUTOS
  • 31,937 POSTS
Hi there, Timing marks for crank & cam as per pics. Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_1_3.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic2_3.jpg
Jul 11, 2008 at 5:11 AM
