Engine Cooling problem
1996 Honda Odyssey 4 cyl Two Wheel Drive Manual
Odyssey fan problem: Car overheated and blew upper radiator hose. I cleaned things up and easily fixed the hose, but the car still gets hot. Turns out that the fan works fine, but only when the ignition is turned off; when the engine cools enough, the fan shuts off as it should. However, when the engine is still hot, as soon as the key is turned to the "on" position, the fan turns off. I could imagine any number of causes, but thought you might have some experience to narrow the choices. Any ideas?
Many thanks!
Many thanks!
Jul 19, 2008 at 9:58 PM
