Hello -
I have attached the info you requested.
Remove mounting bolts and nuts, then steering hanger beam, Fig. 17.
Remove evaporator.
Disconnect connector from mode control motor, then remove mounting bolt and heater unit.
Remove vent/defroster duct, then pipe clamp from heater unit, Fig. 18.
Remove core clamp, then heater core.Do not bend inlet or outlet pipes during heater core removal .
Reverse procedure to install. Do not interchange inlet and outlet heater hoses .
On models equipped with radio coded theft protection system, refer to Vehicle Damage Warnings for system disarming and arming procedures. On models equipped with airbag system, refer to Technician Safety Information for system disarming and arming procedures.
After refilling cooling system, bleed cooling system.
Dec 29, 2008 at 6:40 PM
