1995 Honda Odyssey fuel pump
1995 HONDA ODYSSEY
145,000 MILES • 4 CYL • FWD • AUTOMATIC
BLOCK
I took straps off of fuel tank to lower tank down so I could change the fuel pump, but the tank wouldn't lower, It felt solid against the body. I dont see anything else holding the tankother then the straps? thanks for any help you can give me, Edward Griffin.
Mar 20, 2009 at 5:05 PM
BLOCK
[quote:f5548b80ce="block"]Engine Mechanical problem
1995 Honda Odyssey 4 cyl Front Wheel Drive Automatic 145000 miles
I took straps off of fuel tank to lower tank down so I could change the fuel pump, but the tank wouldn't lower, It felt solid against the body. I dont see anything else holding the tankother then the straps? thanks for any help you can give me, Edward Griffin.[/quote:f5548b80ce]
Mar 20, 2009 at 5:06 PM
