2008 Honda Fit Engine Vibration when CVT engage while car i
2008 HONDA FIT
26,000 MILES • 4 CYL • FWD • AUTOMATIC
CLANBUSTER
This happen suddenly when i do few thing
1) install back my catalytic Converter and sensor.
2) Install Extra piggyback
Now when my car stop at traffic light with gear at D mode, the car virbration and RPM drop to 600.
Tuner try to tune up also same problem.
Noisely from under car, i told them that maybe exhaust leak, but they can't find. What happen....
Sep 6, 2009 at 10:35 AM
KHLOW2008
  • 41,814 POSTS
Hi clanbuster,
Is the MIL indicating?
Did you try to retrieve for trouble codes?
Sep 6, 2009 at 11:02 AM
CLANBUSTER
[quote:e7068a4204="KHLow2008"]Hi clanbuster,
Did you try to retrieve for trouble codes?[/quote:e7068a4204]
sorry, what i MIL ?
There is no engine check light.
I only had super high vibration when come to stop with gear at D mode. RPM too low
Sep 6, 2009 at 5:27 PM
KHLOW2008
  • 41,814 POSTS
MIL = Malfunction indicator light = Check engine light.
Does vibration goes away if you increase the idling speed ?
What is the idling speed when gears are engaged and when in neutral?
Try the PCM relearn procedure to see if it helps.
ECM/PCM IDLE LEARN PROCEDURE
The idle learn procedure must be done so the ECM/PCM can learn the engine idle characteristics.
Do the idle learn procedure whenever you do any of these actions:
• Replace the ECM/PCM.
• Reset the ECM/PCM.
• Update the ECM/PCM.
• Replace or clean the throttle body.
• When the engine or transmission is disassembled.
PROCEDURE
1 . Make sure all electrical items (A/C, audio, lights, etc.) are off.
2 . Reset the ECM/PCM with the HDS.
3 . Turn the ignition switch ON (II), and wait 2 seconds.
4 . Start the engine. Hold the engine speed at 3,000 rpm without load (in Park or neutral) until the radiator fan comes on, or until the engine coolant temperature reaches 194°F (90°C).
5 . Let the engine idle for about 5 minutes with the throttle fully closed.
NOTE: If the radiator fan comes on, do not include its running time in the 5 minutes.
6 . Verify on the HDS data list that the idle learn procedure is complete.
© 2008 Mitchell Repair Information Co., LLC.
If you do not have the HDS, a scanner would do to check and erase DTC if any.
Sep 7, 2009 at 9:17 AM
CLANBUSTER
What is HDS, where to purchase?
Anyway, i did nothing and the idling speed is ok now.
Now the problem is when can reach 2500 RPM, there is loud " toh toh toh" sound from engine, the car jerk jerk, but when car reduce 2400 RPM, nothing happen.
So my let my ECU re-learn, should i keep with this speed at 2500 RPM until stable????
Sep 8, 2009 at 1:22 AM
KHLOW2008
  • 41,814 POSTS
HDS is Honda Diagnostic System which is too pricey for DIY.
Keep rpm at 3,000 until radiator fan comes on, then release throttle and let it idle for 5 minutes, excluding time when radiator is running.
Don't drive the vehicle, relearn is done with engine stationary.
Sep 8, 2009 at 8:41 AM
