2005 Honda Element Reset Cruise Control after Dead Battery
2005 HONDA ELEMENT
120,000 MILES • 4 CYL • AWD • AUTOMATIC
SCHOLTZY
MEMBER
FOLLOW
Battery was DEAD. Replaced it and now the cruise control does not work. Is there a way to reset the cruise control?
Sep 22, 2010 at 9:39 AM
KHLOW2008
CERTIFIED EXPERT
Hi Scholtzy,
Thank you for the donation.
The cruise control system does not require any resetting after replacement of batteries.
Is the master switch indicator light indicating when it is turned on?
Check the fuses, # 4 and # 7 in underhood fuse box.
Check brake pedal switch. Excessive clearance would not allow the brake switch to close the cruise control circuit.
Sep 22, 2010 at 9:46 AM
SCHOLTZY
MEMBER
The Cruise Control light does come on. Fuses are OK.
Sep 22, 2010 at 2:21 PM
KHLOW2008
CERTIFIED EXPERT
Here are the testing procedures for the main switch.
CRUISE CONTROL MAIN SWITCH TEST/REPLACEMENT
1. Release the clips of the switch and push the switch (A) out of the panel, then disconnect the 5P connector (B) from the main switch.
2. Check for continuity between the terminals in each switch position according to the table. If there is no continuity, replace illumination bulbs (A) or the switch.
Ensure there is battery voltage at terminal #1 ( Black/Yellow wire when ignition switch is turned on.
