2005 Honda Element Replacing serpintine belt tensioner pull
2005 HONDA ELEMENT
25 MILES • 4 CYL • AWD • AUTOMATIC
TERLAJE
How to replace the belt tensioner pulley. I would like to just replace the pully only as i suspect it is the part causing the noise.
Can i remove the pulley only or does the entire assembly need to be replaced. If the pulley can be removed, please advise. If the entire belt tensioner assemply must be removed, please advise. '
Thank you.
Apr 24, 2009 at 5:08 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:57edd30f2a="terlaje"]Noises problem
2005 Honda Element 4 cyl All Wheel Drive Automatic 25 miles
Thank you.[/quote:57edd30f2a]
Yes you can just replace the Pulley, all you have to do is remove the center bolt on the pulley.
Apr 24, 2009 at 6:34 PM
