2004 Honda Element Rattling from the door window.
2004 HONDA ELEMENT
40,000 MILES • 4 CYL • 4WD • AUTOMATIC
DIALMAP
Front passenger door glass makes rattling noise on bumps in slightly open position. NO noise in close position. It sound like something needs to be adjusted behind the door panel. I would like to fix it myself, but can’t find instruction how to remove door panel without breaking anything. Please advice.
Jul 3, 2008 at 3:23 PM
KHLOW2008
  • 41,814 POSTS
Hi dialmap,
I doubt you would find anything to adjust except for maybe some loose bolts. Check if the glass runchannels are ok.
You need to remove the door panel after removing the door opener and some hidden screws under some plastic covers. Need to pry these covers off. Other parts of the panel is clip on, use flat piece of metal bar to pry the clips off.
Jul 9, 2008 at 3:28 AM
