1998 Honda Domani
1998 HONDA DOMANI
RUDECLIFFY
Engine Mechanical problem
1998 Honda Domani 6 cyl Front Wheel Drive Automatic
Overheating, temprature guage goes pass the half way mark but does not go all they way to the top especially when am climbing a hill.The vehicle also miss after its been parked for a long time and also during driving. I also noticed the vehicle does not have power and there is a wistleing sound in the engine especially when am climbing a steep hill.
Aug 31, 2010 at 8:43 PM
KHLOW2008
  • 41,814 POSTS
Hi rudecliffy,
If coolant level is corret and overheating or high temperature readings occurs under high speed or load driving conditions, the cooling efficiency is poor. Most likely cause would be a partially clogged radiator or restricted coolant flow, possibly thermostat not opening sufficiently.
Missing could be due to bad spark plugs or wires.
Noise would be difficult to diagnose unless you are able to locate source.
Sep 1, 2010 at 11:24 AM
